parsing a string using an escape character.
I'm writing a vi that is parsing a fram read from the serial port in order to remove some "forbidden" characters.
It works like this: 0xC0 and 0xC1 represents BOF and EOF respectively, but might show up on other occasions.
If they do, they should be preceeded by 0x7D and have bit no 5 complemented. The same applies for the
character 7D.
This means:
C0 -> 7DE0
C1 -> 7DE1
7D -> 7D5D
The vi I'm trying to make is supposed to decode this. It's created from a for loop going through the string character
by character. For every character it reads two bytes into an array. If the first byte is not equal to 0x7D it is simply
passed on as outdata. If it is equal to 0x7D the second byte is complemented and passed on.
The problem is this: When an escape character is removed I'd like the for loop to skip ahead one step, or there
will be a missplaced extra character in the outdata. This isn't done easily
Pictures of the vi, in it's two different cases is provided.
(4,417 Views)
Hi Tzench,
instead of using the "i" terminal you can use a shiftregister to build your own pointer. Add one in the second case and two in the first.
Mike
Message Edited by MikeS81 on 01-26-2009 11:36 AM
(4,414 Views)
Hi Tzench
I hope I correctly understood your problem. You want to replace every 7DE0 with C0 etc. For this you may use the "search and replace string" function. Se picture. This will work the other way also C0->7DE0Smiley Wink
Message Edited by t06afre on 01-26-2009 11:54 AM
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(4,402 Views)
I tried this and it worked rather well, except for that for every escape character that is removed a zero is added at the end of the outdata string. Is there something simple I could do or should I change it all to a while-loop?
(4,367 Views)
This seemed like a very good solution, but I didn't get it to work properly. I entered 7DE1 as a hexadecimal numerical constant and typecast it to a string in order to use it as a search string. It didn't find and replace the string I wanted to. I suppose this is a data representation problem.
(4,362 Views)
Take a look at this example. Your task should not be a problem.
Good luck
(4,351 Views)
Hi Tzench,
why not simply create a string constant, switch to "hex display" and enter "7de1" (without quotes) ???
(4,325 Views)
