Using NI-9217 with cRIO-9081
How do you configure a NI-9217 in LabVIEW FPGA.  In LabVIEW and LabWindows you would use DAQmxCreateAIRTDChan to setup the RTD Type, Resistance Configuration and other parameters.
Paul
Message 1 of 9
(4,185 Views)
You can find examples of NI-9217 in NI example finder.
CLD Using LabVIEW since 2013
Message 2 of 9
(4,150 Views)
Yes I know about the NI example finder.   But they are all for LabVIEW or LabWindows.  I am using LabVIEW FPGA.  I didn't think you could use standard LabVIEW NI-DAQmx libraries with LabVIEW FPGA.  Can you?
Message 3 of 9
(4,138 Views)
Hello Paul,
Have you take a look at the following documentation:
National Instruments Online Resource Title (0): Taking Your First Measurement in LabVIEW FPGA (Data Logging)
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x3ruCAA&l=en-US
National Instruments Online Resource Title (1): Advanced Data Acquisition Techniques With NI R Series
https://www.ni.com/en/shop/data-acquisition/advanced-data-acquisition-techniques-with-ni-r-series.ht...
The resource (0) is the exact application that you need and the (1) is in case you have other cards need an extra step to function.
I hope you have a good one!!!
Message 4 of 9
(4,134 Views)
JKarma,
Thanks.  I have been doing FPGA programming for about two years using NI-9201, NI-9208, NI-9403 and NI-9485.  This is the first project that I have a NI-9217 module.  I have used them before in LabWindows and  you usually have to configure them.  Mainly the RTD Type, Resistance Configuration (2, 3 or 4 wire) and the Current Excitation Source (Internal or External).
I do not see any method or property where those settings can be configured.
Paul
Message 5 of 9
(4,131 Views)
Hi Paul,
have you tried to check the module properties in the FPGA part of your LabVIEW project?
Message 6 of 9
(4,122 Views)
Yes I did.  All you get is the Name Type, Location, Calibration Mode, and Conversion Time.
Paul
Message 7 of 9
(4,118 Views)
Hi Paul,
Oh, as I'm on vacation now you need to wait for two weeks before I get back to work to check that with a real cRIO.
I mainly use the 9217 with PT100, 4-wire, internal excitation. You can read the resistance value and apply any calculation you want...
Message 8 of 9
(4,113 Views)
I have solved my issue.  I made the assumption that the tech wiring the 9217 knew how to read a schematic.  He missed wired the cable on all 5 of the RTDs.  Once I re-wired I get real values.
Thanks for the help.
Message 9 of 9
(4,104 Views)
