Using PCI 6221 and ACC001 modules to acquire analog voltage signals
I have written a vi to acquire voltage signals from proximeters to measure displacement from proximity probes.  I have a SCC2345 front end with ACC001 modules.  It appears the PCI 6221 can accept voltage inputs without the SCC2345 front end.  Am I reading the manual correctly?
Regards
Ron Brook
(2,858 Views)
Hi Ron,
yes.
(2,829 Views)
Great!  Then forgive this one last question.  Why do they sell analog voltage input modules for the SCC2345 ?
(2,821 Views)
Accepted by Coryman
Hi Ron,
because several types of sensors need some "special" requirements like (low-noise) amplifiers, excitation current/voltage, rectification and/or level shifting, …
Do your sensors need some amplification and excitation?
(2,817 Views)
No.  They have their own signal conditioner modules.  Supply 24 volts and the output is a solid voltage signal.  DC for the distance between the probe tip and the shaft, AC for the dynamic motion between the probe tip and the shaft!
Ron
(2,795 Views)
