Using Renesas E1 Emulator with LabVIEW
Dear Sir,
I am high university student. Actually I am working on my final project and I need to use the RFP.dll file used with the "Renesas Flash Programmer".
Actuelle I loaded the DLL to LabVIEW and I need to have informations about inputs and the outputs of the used functions in this DLL. (such as : RFP_Open, RFP_Wirite...)
Best Regards,
(5,157 Views)
So what's your point? At which point do you need help?
(5,136 Views)
Dès que possible
(5,123 Views)
 For my internship, I have to do a labview program that will automate the automatic programming installation.
For that, I must first try to communicate the emulator E1 with labview. But unfortunately I do not have their source code!
So I downloaded a flash file renesas dll (RFP.dll) which is supposed to allow me to get this code according to the manufacturers of the probes.
However, I do not see how to recover the source code after with Labview, I think it is necessary to use "call a function of a dll" but I can not correctly configure the input so that it detects my probe.
Labview does not detect a problem, but nothing happens when I run the program.
I hope you can help me.
Thank you
(5,116 Views)
Hi Roua,
I am not familiar with the Renesas Flash Programmer library. Do you not have any documentation to go along with the library?
I would also look into Event-Driven Programming in LabVIEW to implement the code that you have built.
Best,
David F.
Applications Engineering
(5,099 Views)
