Showing results forĀ
Search instead forĀ
Did you mean:Ā
Using Skype with Labview
Hey,
Remove the "reply to number" in the CreateSMS vi.
Also, make sure you add +1 (US) before the phone number.
I got it to work last night. If you can't get it, I can send you the vi I use.
-griplegraple
Message 11 of 16
(1,901 Views)
I still get an error. I deleted the Reply To Number in Skype4COMLib.ISmsMessage in CreateSMS.vi, but when I run it I get an error in Skype4COMLib.ISkype; the error is 1 (Incorrect function.  in SKYPE_SDK_CreateSMS.vi). Yes, I would appreciate seeing the VI you got to work.
Message 12 of 16
(1,891 Views)
Can you post up a snapshot of your block diagram of the CreateSMS vi?
Message 13 of 16
(1,888 Views)
Actually, nevermind--I just got it to work. I had to run it from SendSMS, not CreateSMS. Thanks guys!
Message 14 of 16
(1,885 Views)
Hello, Guys. I have a question: i need to make video-call throught this labview program (automaticaly). If i do it throught standard method "Calls" - i get only audio call. And then i must to press button in Skype "allow video-translation" for video-call. Another  words, i need to make button "video-call". Just one standard Skype-button, VIDEO-CALL. Thank you very much. :womanvery-happy:
Message 15 of 16
(1,786 Views)
Are you sure it's a good idea to make a "surprise" video call?  Maybe video is disabled by default on purpose?
Bill
CLD
(Mid-Level minion.)
Message 16 of 16
(1,763 Views)
