Using USB-8451, and AD7747 from Analog Devices to measure capacitance and convert the capacitance to digital output
I am new to LabView and data aqusition. I have LabView 8.5.1 installed on my laptop, and I studied the Getting Started document of LabView, except the data aqusition chapter.
I have microfabricated a differential capacitive sensor, and now I want to test the capabilities of my sensor.
After asking NI engineers, I have been suggested to use USB-8451 with AD7747 (24-Bit Capacitance-to-Digital Converter) from Analog Devices because AD7747 has I2C serial interface.
I have ordered USB-8451, AD7747, and Evaluation Board for AD7747. And I am waiting for them.
Are there any suggestions about how to connect my differential capacitive sensor to AD7747, and eventually to USB-8451?
You may want to know some further information to answer my question:
*The sensor is similar to the sensor on pages 501, 514, and 515 of "Microsystem Design" book from author Stephen D. Senturia.
*The datasheet for AD7747 can be reached from this link: http://www.analog.com/static/imported-files/data_sheets/AD7747.pdf
*My purpose is to make a very precise and accurate "displacement measurement micodevice" by using "the change in the capacitance" during the motion of the mobile fingers of the sensor.
As an initial challenge for myself, I will feel satisfied if I can measure the capacitance change in my sensor when I apply an external mechanical disturbance to my sensor. For example, there must be a change in capacitance if I just swing my hand from top of the sensor region.
I am looking forward for your reply,
Thanks in advance,
Sincerely,
sriverfxtr
Message 1 of 1
(3,352 Views)
