webpage manipulation
I did a few searches on the forums, but I cant seem to find someone that directly solved this issue:
I have data being collected at a remote location. Every once in a while, I save it to the C drive.
I would like to transfer the file to a webpage, that all of my co-workers have access to.
To upload to this page you must:
1) Log in
2) click a link
3) click another link
4) fill in 3 boxes
I know that you can interact with webpages via ActiveX controls, but is it possible to do this programmatically?
Because I know exactly what I need to send to each box, I just dont know how to do so.
Anyone have somewhere to get started? Or a thread involving this that I missed?
Cory K
Message 1 of 18
(5,530 Views)
Message 2 of 18
(5,528 Views)
I still seem to be stuck on this issue.
For a simple example, I used Facebook, since all that was on the log-in page was the login credentials.
I tried to modify the VI Mike pointed me to, but I dont think I did so correctly.
Can someone take a look at the attached VI and tell me what I am doing incorrectly?
When I enter the email and password, I get :
Error 97 Occurred
Possible Reason(s):
LabVIEW: Null Refnum was passed as input.
Does anyone have a facebook account they could try logging onto?
(Note: If you modify the VI, please keep it in version 8.5, thats all I have at home Smiley Tongue )
Message Edited by Cory K on 07-04-2009 06:44 PM
Cory K
Message 3 of 18
(5,482 Views)
i tried it with my account and ended up with the same error:(
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
Message 4 of 18
(5,471 Views)
HI Cory,
i think the document name creates this trouble. If you use the property->length on the forms refnum, then you can see that there is one form. If you connect a 1 to the index input instead of the "loginform" to the name input, theni can set the email and the password.
You should use the "ReadyState" property inside a loop instead of the fixed wait time.
Mike
Message Edited by MikeS81 on 07-05-2009 08:30 AM
Message 5 of 18
(5,465 Views)
OK I will give that a shot.
Cory K
Message 6 of 18
(5,451 Views)
I am getting there, but not quite.
When I enter the email and password, they arent placed in the correct boxes.
When I run the attached VI, it enters
Email :  email@server.comemail@server.com
Password : (blank)
I have tried changing the 'Form Element' indexes but it still wont work.
I think it may have something to do with this:
The 'afterBegin' constant was placed in the VI I found. I'm not really sure what it does, or if I should have something else there.
Cory K
Message 7 of 18
(5,446 Views)
Sorry, I forgot to attach the VI.
Cory K
Message 8 of 18
(5,444 Views)
Hi Cory,
maybe i was not clear enough. Change only the name of the form to the index.
See the attached picture.
With this changes it works for me.
Mike
Message 9 of 18
(5,430 Views)
You were correct Mike.
Now I have a different issue.
Say I enter the credentials once:
Email : email@email.com
Password : password
If I try a second time, they will now append to the last entry:
Email : email@email.comemail@email.com
3rd Time
Email : email@email.comemail@email.comemail@email.com
.... etc
Do you know how I can clear out the entry before entering the new one?
Cory K
Message 10 of 18
(5,420 Views)
