Using Windows Domain credentials with Remote Panel
I am looking for a way to deny remote panel access based on Domain login credentials. Is this possible natively to LabVIEW, or is it going to require calls to the Windows .NET libraries?  (which I dislike doing)
(3,666 Views)
Adding a solution in case anyone comes wandering by later looking.
As far as I can tell it does require a call to the API, but a fairly simple call.
(3,653 Views)
I tried this code for "Machine/PC" and it works well. If  I give correct username and password it gives me "TRUE" output. How to get list of available user in Machine/PC?
(3,187 Views)
