Using XY-Plot to plot Earth longitude and latitude
Hello everyone, I am new to LabVIEW and I am trying to use XY-Plot to graph Earth longitude and latitude (like the image below):
However, my code did not work well, nothing appeared except the scaling of x and y axis changed. I cannot see any problem here, could someone help me point out what I did wrong?
Thank you very much!
(2,063 Views)
Accepted by minhhoang_65
Hi minh,
You did not attach your VI, but just an image of the block diagram…
You use an ExpressVI just to create a plot.
You use matrix functions when they aren't needed.
You do stuff in a loop theat belongs outside the loop.
Example:
(2,025 Views)
And if you don't like loops and the colors blue & pink, here's an alternative 😄
(1,994 Views)
Thank you so much! Got it now!
(1,970 Views)
