Using a Property node to ensure i have an admin log in and password.
Hi Guys. Im doing a project and seem to be having some issues setting up a username and password using a property node. I have no problem getting a username and password set up to allow access but my project requires me to do it through a property node...... The project reads:
Use a start button to start this program running.
Use a property node to ensure the user is logged in as admin and
Use a password to check if both username and password are entered correctly.
The property node will be used to ensure the Start button is visible – or not.
Create a 2d array of Temperature readings (24/7). Simulating the data for 24 hours and 7 days
Output this to a waveform chart..........
As you can see from my VI, I have the start button in place but i am struggling to find any literature or help on using a property node for what im trying to achieve. If anybody could point me in the right direction. I would really apricate it.
(774 Views)
Accepted by topic author EDiddle
Probably just get the "User Name" property from an App property node and check to see that it equals "admin"?
(766 Views)
I recommend to do a few more basic tutorials before even attempting whatever you are trying to do.
There is a difference if the logged in "OS user" has admin privileges or is named "admin". It is also not clear of you are creating a users system for your app or you are actually talking about the OS user account.
Your code shows a complete lack of even beginner skills. This needs to be implemented as a proper state machine.
  • An event structure belongs into a toplevel while loop and you need to be careful about event configurations, for example (by default) your UI would lock up forever if the start button is be pressed a second time later.
  • Autoindexing at a while loop boundary is dangerous, because (1) eventually you'll run out of memory and (2) all data is lost if the VI is aborted.
  • You talk about a 2D array of readings, but there is no 2D array anywhere in sight. Where is the chart you mentioned?
  • Recording temperatures 24/7 probably required saving to disk at regular intervals.
  • You can use a "visible" property node to hide the start button or a "disabled" property to disable and grey it out unless the user is authenticated. Disabling is clearer to the user because he can tell that there actually is a button but it can currently not be operated.
  • I don't understand the use of a property node to authentical a user. A property seems quite useless for that.
  • I think we told you elsewhere how do do a running average correctly. Temperature reading typically don't have a lot of noise, so why do you think you need to average at all? There are other ways to filter.
  • Why is the current reading not part of the average? Are you aware that the first 10 averages are incorrect?
(726 Views)
Hi Altenbach. Thank you for your reply. Yes you are correct. I am a beginner and really trying to learn. Could you please point me in the right direction of the tutorials you have mentioned as i would like to take your advice before attempting to proceed any further.
Regards, Enda
(634 Views)
