Using a Write to Measurement File Vi in LabVIEW 2018.
To LabVIEW discussion board:
Is there a simple way to document integers and store them into an excel spreadsheet using Write to Measurement FIle Vi?
Fig 1. Here is where I put the Vi, it is intended to log data after an iteration has stopped.
Fig 2. Here is the parameter that I am using.
Fig 3. This is the message I get after iteration stopped.
Thank you.
(2,998 Views)
Accepted by topic author SparkBeetle
Hi Beetle,
when does that error message pop up?
Do you have the target file opened in Excel while trying to save data to it?
Why don't you just use WriteDelimitedFile instead (with append? set to TRUE)?
(2,971 Views)
To GerdW:
It worked! The output looked like the following, and I can manipulate it in excel.
This feature saves me time and effort on data logging.
1.000
3.000
8.000
3.000
Thank you.
(2,959 Views)
