Using a mouse to get cell value
I have an array of data points that I can also display in a table.  Is there a way to have a cell value displayed into a string when I click that specific cell?  I wasn't sure if this is done through a property node or if it is possible to begin with.
(3,674 Views)
Use the EditPosition property and wire the row and column info to an Index Array function.
(3,666 Views)
alright.  How to you input the index based on the cell that I click on?
(3,649 Views)
Sigh... Nobody tries anymore...
(3,644 Views)
OK...nevermind.  Just figured out what you had mention.  Thanks a lot!!!
(3,641 Views)
