which are the lab view compatible processors or microcontrollers
Hello All
I am an engineering student. And I am new to LabView
I have a program which is compiled using LabView. I wanted to know which are the micro-controllers or processors that are compatable with labview. So that i can dump the program and start working on my project.
(3,061 Views)
Your question is not clear. What do you mean by "dump the progream and start working on my project"? Dump where? New Jersey?
Are you asking what the system requirements are for running LabVIEW? If so, then you can find that here (which you would have easily found if you had tried a search). Or, are you asking what microcontroller you can program? The answer is none, unless you also have the LabVIEW Microprocessor SDK, which costs $12,000.
Please provide more details or a better explanation of what you're looking for.
(3,057 Views)
