Showing results forĀ
Search instead forĀ
Did you mean:Ā
Using an enable to write data
I want to update lets say some LED's from a status reponse message from my device. I can compare the bytes of the message to vaidate it but how can i only allow the array that drives the LED's to be updated only if the message is valid..
thanks
(3,752 Views)
Put a case structure around your write.
(3,741 Views)
What is the device that is sending the status messages?
How are these messages being sent?
What do these messages look like? strings? numeric codes?
It sounds like LEDs are just an example of what you might want to control. What are you really wanting to control with these messages?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,721 Views)
Upload your VI
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(3,718 Views)
put a while loop with case structure inside and keep tacking the value making string comparision
(3,701 Views)
Yes doing inside while loop is good idea. Use some delay for while loop execution.
--Ranjeet
(3,693 Views)
