Using and deploying Image functions without Vision RTE
Hi all!
I have never thought that I could find this topik... My problem was the same and successfully solved by this "manual". Thank you very much all of you!
btw, I have  questions
- I did not find the following dll: NIVisSvr.dll   - in my system32 folder. (LV2009 sp1) - will it couse any problem?
The attached vi contains IMAQ ReadFile , IMAQ Create.vi
As I know these VIs are in connection with Vision Dev. Module.
How could it be possible that, when I start the exe the Activation panel does not appears? - ( I have only Runtime Engine Installed.)
So, these VIs can be used without License?
How can I know what VIs need License?
Thank you!!!
+++ In God we believe, in Trance we Trust +++
[Hungary]
Message 11 of 16
(2,077 Views)
This DLL is a part of Vision Development Module (or Vision RunTime Module). Install one of them (even in Evaluation Mode) and you should found this in system32 folder. Not sure if this DLL included or not in old version of Vision.
These VIs listed here: Which VIs are Installed with NI-IMAQ and Vision Acquisition Software?
Andrey.
Message 12 of 16
(2,073 Views)
If these Vis requies VisionRT Licence, How can I use IMAQ ReadFile, Imaq Create without it?
See previous example...
[Hungary]
Message 13 of 16
(2,065 Views)
 You probably misinterpret my previous answer. All VIs listed above are included into Vision Acquisition Software and do not require Vision Development Module or Run-Time license. So, you can use IMAQ Create and IMAQ ReadFile as well as other VIs listed in given document without installation and activation Vision Development Module or Vision Run-Time.
Message 14 of 16
(2,057 Views)
Thank you very much again!
Have a nice day!
[Hungary]
Message 15 of 16
(2,054 Views)
 I installed and did not find it....  NIVisSvr.dll
Could you send me one?
[Hungary]
Message 16 of 16
(2,037 Views)
