Using arduino DUE and MPXV7002DP and LABVIEW to get pressure data
Hi all, I apologize if this has been asked before but i tried looking for solutions but i have found none. I have no experience in using arduino, labview or anything electrical(mechanical engineer here) and thus would need quite a detailed answer if any.
I would like to take pressure readings with MPXV7002DP. The analog output 0-5V would then be transmitted to the ARDUINO DUE and thus transmit the pressure readings to my computer through MATLAB.
May i know if this is doable using labview, or should i stick to arduino code.
specifications:
http://www.nxp.com/assets/documents/data/en/data-sheets/MPXV7002.pdf- transducer
Arduino DUE
Microcontroller: AT91SAM3X8EA
Operating voltage: 3.3V
Input voltage(recommended): 7V - 12V
Input voltage(limits): 6V - 20V
Digital I / O pins: 54 (of which 12 provide PWM output)
Analog input pins: 12
Analog outputs pins: 2 (DAC)
Total DC output current on all I / O lines: 130mA
DC current for 3.3V pin: 800mA
DC current for 5V pin: 800mA
Flash memory: 512KB all available for the user applications
SRAM: 96KB (two banks: 64KB and 32KB)
Clock speed: 84MHz
Warning:
Unlike other Arduino boards, the Arduino DUE board runs at 3.3V. The maximum voltage that the I / O pins can tolerate is 3.3V. Providing higher voltages, like 5V to an I / O pin could damage the board.
(3,738 Views)
hi all,
I changed the board to a MEGA and everything is working as usual. Just installed the LIFA_base file and i am all good to go.
(3,702 Views)
