error -2147221080 (0x800401A8) with Excel ActiveX on sheet access
Hi all !
I get this error while accessing an excel sheet.
Could it be linked to file permissions or something?
Thanks!
(3,511 Views)
Well... it kind of resolved itself.
I just added a 'Worksheet' property node before the 'Range' method and it then worked. I then removed the property node and it was still working!
I don't understand exactly what happened here...
Anyone got an idea?
(3,505 Views)
i have a similar error and i dont know what happend
(3,281 Views)
Had the same issue.  I started with a working vi that I changed for a different purpose.  It was after I changed it that the error started, so I could go back and trace the error.  In my case, it was caused when I removed the error wire that went from the invoke 'worksheet/activate' node to the invoke 'worksheet/close' node.  Rewiring the error wire fixed the issue.
(2,983 Views)
