Showing results forĀ
Search instead forĀ
Did you mean:Ā
Using claps for actvation
Hello, I have a problem with using claps.
I am trying to use clap as a switch that a system turns off and on using a clap but unfortunately, I cannot have the system running as the microphones are constantly recording audio so I am unable to find the minimum and maximum amplitudes to determine if it is a clap or not as they are constantly changing.
would you please explain to me in simple terms as I am new to the LabVIEW.
thank you.
Message 1 of 16
(5,100 Views)
Hello I had the same problem here
thank you.
Message 2 of 16
(5,070 Views)
Hi sina,
Don't they clap as intended? šŸ™‚
Isn't this expected behaviour? You surely want to record audio data constantly to be able to recognize the clap sound!?
I don't think a simple min/max comparison will fulfill the requirement. Maybe some FFT to detect typical clap sounds?
When you are new to LabVIEW you should note the Training resources offered for free in the header of the LabVIEW board!
Message 3 of 16
(5,058 Views)
Hello Gerdw
So let me put it this way.
I want to create a switch by detecting claps but i was unable to use it as a switch. I have some ideas to use shift register but i dont know how to implement it
Would you please help me?
Message 4 of 16
(5,052 Views)
Hi sina,
Sure!
Why don't you attach your VI and tell us why you cannot implement your ideas using shift registers?
Message 5 of 16
(5,050 Views)
Sure
ā€ƒ
Here is my VI although it is not working
Would you please tell me how should i proceed?
Thank you
Message 6 of 16
(5,034 Views)
Hi Sina,
@sinaaa wrote:
Sure Here is my VI although it is not working
Ok, all we get is a blurry photograph, even taken with wrong orientation of the camera.
What would you say when you ask for some C sourcecode and all you get is a blurry image instead of a text file?
Proceed with attaching the real VI!
Message 7 of 16
(5,030 Views)
sorry, here you go.
Message 8 of 16
(5,027 Views)
Hi Sina,
you already use the shift register correctly, I just rearranged some parts of your VI:
So what is the real problem with your VI? (Apart from the problem of a buggy (IMHO) calculation of pump speed.)
Message 9 of 16
(5,025 Views)
Since you only check the max value, any loud sound would trigger the function. It might be good enough, but the aforementioned FFT would be a better solution, and e.g. check the power of some key frequencies, like 5 kHz (i don't know if that's a big one of a clap, but such a short, sharp sound should have some fairly high frequency components, measure and compare)
Qestit Systems
Certified-LabVIEW-Developer
Message 10 of 16
(5,020 Views)
