Using cluster values in a formula?
Accepted by THN
As already explained, you CANNOT wire it that way. You said you tried a shift regsiter but obviously you did not. Use a SHIFT REGISTER to pass data from one event to another
Message 11 of 14
(1,381 Views)
I actually did it, but i rollback, since it was not working. Because, 1st of all, i'm a beginner with Labview, and 2nd, when i do the shift register, all the info sticks to only 1 shift register. And i need it separated, in order to put those values into the formulas. So if you can help me wiring them, i will me pleased.
I attached what i did.
TN
Currently using LV 8.5
logo
Message 12 of 14
(1,379 Views)
Nevermind, i think i got it. Just needed to add more shifts.
Thanks for your time.
TN
logo
Message 13 of 14
(1,376 Views)
What I did not notice when I looked at the code is that you are just reading the cluster and not modifying any of the values. You just have to put an Unbundle by Name in the event with the formula. Just like DeOdderKeith said.
Message 14 of 14
(1,374 Views)
