Using conversion functions
When using the numeric conversion functions, such as to I16, what determines whether a number greater than the upper limit is coerced to the upper limit or is wrapped around from the lower limit?
(2,813 Views)
In general, LV will coerce the way that the CPU does. Integers to
integer will take the lower portion, performing a modulo operation.
Float to integer will pin, typically to the correctly signed maxInt.
If it is important to your algorithm, build a quick test VI.
Greg McKaskle
(2,813 Views)
