historical database
I can access to Historical Database Citadel through Labview and i get error
code Ox80004005.
Maybe somebody knows what is going on?
Monica
(3,621 Views)
_____
Couple of things:
1. Please provide mopre info': How are you accessing the Citadel database? Are you using the Historical VIs from DSC palette? Or the HDV in MAX or the HTV in DSC? Are all of these failing? Are the Citadel Services running?
2. You may want to post your query in the Datalogging and Supervisroy Control section of this forum for faster response. They deal with Citadel, DSC, etc. Here's the link:
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RPAGEID=8&RFORMNUMBER=3&RHIDETAG=TRUE&UCATEGORY_0=_51&UCATEGORY_S=0
Khalid 🙂
_____
(3,621 Views)
I using the Main.vi to connect to Engine...loading configuration "*.scf" ..launching OPCServer... starting Historical Database...runninig and stopping with error accessing Citadel. When I delete directory "data" which is in the path in Historical Logging Configuration in Tag Configuration Editor - he create the new directory "data" and everything is OK - no error accessing. Why?
(3,621 Views)
