Using lat long with imaq axis matching
I am having trouble associating the lat long values with the imaq image extent, firstly the imaq has an indirect coordinate reference with y axis icreasing top to bottom which is reverse to latitude values. Secoundly, I am unable to change the value of origion to any value other then (0,0). Can anybody help me or provide any guidence in this reard...
(4,068 Views)
I am having the same problem, can somebody for God sake, suggest some solution....
(4,065 Views)
Hi Amir13,
I would suggest you post this to the machine vision forum, http://forums.ni.com/t5/Machine-Vision/bd-p/200 , I think you'll get a better response there.  After you do that, could you please post a link to the new post here so user Sets can find it?
Also, when you make your new post, please attach an example VI and/or picture of what you're trying to accomplish.  Sometimes this can help describe the issue in more detail than text can.
Bobby Breyer
Applications Engineer
(4,014 Views)
Accepted by amir13
I have developed a relevent solution using various resources a screen shot is attached if anyone faces a relevent problem
(4,005 Views)
This is not exact solution
(3,939 Views)
Any suggesstions ??
(3,834 Views)
