Using multiple tables but using one common scroll bar
Hi
Im using 3 different string tables but i would like to use one common scroll bar to move vertically.
Any ideas?
(4,241 Views)
I having trouble linking multiple tables together with the scroll bar? i need these tables to scroll together
could anyone help
(4,233 Views)
Create your own scrollbar.
Set it's min\max\page size so it matches the table data (min 0, max the size, page the nr of visible cells).
Catch it's value change event, and set the top left cell of the tables to the scrollbar's value..
(4,213 Views)
Accepted by topic author KJ26
Like this.
If you want a horizontal scrollbar, it should be pretty easy to adapt.
Added benefit: The native scrollbars allow scrolling beyond the content, which is usually just silly...
(4,193 Views)
Thank you
(4,115 Views)
