Using network shared variables in two computers connected via a network switch
let me start by saying im a rookie to the programming environment but i have used Labview a couple of times to understand the basics,  i have a computer and a laptop (both using vista), both of them with Labview Full development System (Student ed. with Mathscript) installed, so what im tryin to do is to use the built in microphone located in the laptop to aquire sound and then use a Shared Variable to transfere the sound signal from the laptop to the computer, the laptop and the computer are connected to a network via a network switch and ethernet cables,  so far i nothing worked, i can manage to create the shared variable in the laptop and use it there but it doesnt appear in the computer, im not sure whats the problem i have even disabled firewalls in both systems, help from anyone wil be appreciated.....
(2,918 Views)
Hi Lukie,
This KB should be of some assistance to you.
Trouble shooting network published shared variables
Also the following link gives some instructions on the use of shared variables.
https://www.ni.com/docs/en-US/bundle/labview/page/binding-shared-variables-and-other-ni-psp-data-ite...
I hope this is of some assistance, let me know if you have any more problems.
All the best,
Message Edited by mickeyw on 08-05-2008 12:29 PM
Mike W
National Instruments UK&Ireland
(2,894 Views)
Thanks a lot Mike finally it worked, thanks for your time!!!!!
Message Edited by Lukie on 08-05-2008 02:17 PM
(2,883 Views)
