modbus write registers
I am succesfully using the Modbus Library vis to read some holding registers in a Honeywell UDC controller. However, I need to write to the set point registers
400107 and 400108 which is a floating point register. The Modbus vis only accept values in a high word and a low word, so how can I use these vis to write a value of 60.5, for example. In other words I need to know the equivalent of 60.5 in low and high words (16 bit).
When I read the registers I convert the high and low words to SGL precision, but I do not know how to do the reverse.
Any ideas??
(3,735 Views)
You can just use the split/join number functions and a type cast to convert back and forth.
Message Edited by Karissa on 08-03-2008 10:37 PM
_______________________________________
Systems Test Engineer
Certified LabVIEW Architect (CLA)
(3,723 Views)
Ok I just tried it and it works in LabVIEW 8.5 but not in LabVIEW 8.2, I think there was a bug in the Typecast function in the earlier LV versions.
(3,717 Views)
Woops, it works in the older versions of LabVIEW if you change all the DBL data types to SGL.
(3,703 Views)
    Thanks a lot for your suggestion... It works excellent..
Thanka a million
(3,678 Views)
