Using of MGI read write anything
To the OP:  your example worked just fine for me here, including the Enum.  Any change I made and saved could be seen in the text file and came back correctly on the next load.  I tested with LV 2016 and MGI R/W Anything 2.1.4.4, but I've generally found MGI R/W Anything to work fine with enums for more than a decade. What specific problem are you having?
Back in the early-ish days of DAQmx, I once tweaked a low-level type resolution case structure to add support for DAQmx physical channels and terminals, but later changed over to the practice of defining my typedef'ed cluster to use simple strings for such things so I could use the MGI toolkit without mods.
-Kevin P
Message 11 of 14
(1,233 Views)
-Kevin P
Everything is saved and reloaded correctly.
Numbers and strings are written correctly to the input cluster but I can't manage to write the saved value back to the enum in the input cluster. In the output cluster in saved value in displayed correct.
Message 12 of 14
(1,226 Views)
For each of the property nodes you write to in the "Load" case, double-click its top bar to highlight it on the front panel.  I think you'll quickly see what the problem is...
A better general alternative is to right click the input cluster control, select "Create->Local Variable", and wire to it to update the whole cluster all at once.
-Kevin P
Message 13 of 14
(1,212 Views)
Accepted by topic author Heino
-Kevin P
I have seen my mistake.
With the local variable it works also.
Thank's for support
Heino
Message 14 of 14
(1,190 Views)
