Using radio button to control while loop in subvi
I have a radio button in a while loop in a subvi and I would like to control it using the main vi.
I have looked at:
https://forums.ni.com/t5/Example-Code/Using-Control-References-to-Pass-Access-of-Front-Panel-Control...
https://forums.ni.com/t5/Archive-TKB/Using-Control-References-to-Update-Between-Top-Level-VI-and/ta-...
My radio button has two states, On and Off, which are indicated by a round led for each. I am having difficult comparing the value of the radio buttons property node to the state that I want. For example I want the while loop to end if Radio Button value is On. I tried using variant to data, but I either did it wrong, or that is not what I am supposed to do.
Message 1 of 8
(4,679 Views)
do you mean this vi
Message 2 of 8
(4,655 Views)
Sort of except this is what it would look like to control it from the subvi. I want to be able to control it from the main vi.
Message 3 of 8
(4,633 Views)
so you need this
Message 4 of 8
(4,607 Views)
So it will not work without making it an event?
Message 5 of 8
(4,592 Views)
No I dont think so
Message 6 of 8
(4,577 Views)
No you don't have to use an Event Structure to perform this task in the Subvi.
See the attached example.
If you get the "Radio Buttons" reference from the Subvi, you can directly control it from your Main vi.
steve
Founding (and only) member of AUITA - the Anti UI Thread Association.
Message 7 of 8
(4,560 Views)
oh your are right stevem
your code is really work nice
Message 8 of 8
(4,546 Views)
