SPI Express VI not found
Hi, I want to communicate with a hardware using SPI protocal. I've installed myRIO Module, but I didn't find the myRIO or SPI Express VI on my function Palette. I don't have a NI myRIO hardware right now, is that the reason the module didn't show up? And is there any way to get my work done without using a NI myRIO hardware? I have a NI usb 6211.
(3,417 Views)
Hi.
From the project explorer right click on your project, than <New>, <Target and Devices>. Set <New target or device> check box and than select your myRIO type. After create New VI from your target. In this VI you can find your SPI and myRIO Express VI`s IF YOU HAVE ALL DRIVERS INSTALLED.
Best Regards,
Edgar Shadyan.
(3,385 Views)
Did you install the myRIO toolkit because you intend to purchase a myRIO, or because you saw that it has functions for SPI and you hoped it would work with your hardware that is not a myRIO?
You can do SPI at slow speeds with the 6211 but you have to do all the timing logic in software. Occasionally someone posts an example of such code here on the forum, for example https://forums.ni.com/t5/Digital-I-O/Implementing-I2C-or-SPI-with-Pxi6508-in-Labview/td-p/554383
Another option is a dedicated SPI device such as the NI USB-8451
(3,341 Views)
Also, some of the fairly low-cost USB to FTDI adapters support SPI using the libmpsse library.
(blog)
(3,307 Views)
