equalizer, changing value of filters in REAL time
I am new to LabView and I would like to ask you a few questions.
I am working on my bachelor thesis. The point is to design a hearing aid for hearing loss compensation.
In this thesis I was able to create a few filters which are firstly used to distort audio track and other filters to repair it.
However I am stuck on a problem where I am not able to change filters in REAL TIME.
Is there any chance I can create an equalizers which I will be able to change during the listening of a audio track ? To distort some frequency bandwith and then to amplify it on different filter ?
I am using labview version 2015
Thank you very much.
Looking forward for your help.
(2,860 Views)
Hi Petrysko,
                        I would suggest the following community page
                        The example was created for NI myDAQ and NI ELVIS, but I think that if you do not need the acquisition part and already have the signals, you should be able to (re)use only the equalizer piece of code for your own purpose.
Denis
(2,805 Views)
