Using the LabView application builder
Hi.. I'm trying to build an application from my labview project and I want it to run it in a computer with no Labview installed. When I'm trying to run this Error shows up: Unable to locate the Labview Run-time engine. Is It possible to run my application in this computer? or definetily I have to install Labview on it in order to run it.
Thank you
(2,779 Views)
You need to install the LV runtime engine corresponding to the LV version of the development environment.
This can be easily accomplished by creating an installer for the executable. Also an option in the project build menu.
Otherwise search the Ni website and download it.
André
André (CLA, CLED)
(2,777 Views)
