Using the SciLab LabVIEW gateway
Has anyone had any success running commands through the SciLab Scripting Node that are avaialble through an installed module in SciLab?  I am trying to run a command (emd) that is available through the EMD ToolBox, but am getting an error (Error 1050 occurred at LabVIEW:  Error occurred while executing script. Error message from server: . in Untitled 3) that doesn't really provide much insight as to what is wrong. Essentially, the input (in) is a 1D array of reals, the output (out) is a 2D array of reals and the code in the node is out = emd(in).  This works when I am in SciLab, but fails when using the SciLab scripting node.  I am able to run other simple scripts using the SciLab scripting node (for example, if I use out = sin( 10 * in), I get a 1D array of reals that is what it should be), so I do not think that this is an issue with the Scripting node.  I can't find much in the way of documentation, so any help would be greatly appreciated.
I am running SciLab 5.4.0, with the EMD Toolbox installed (installed using ATOMS), LabVIEW 2010 and the current version of the SciLab LabVIEW gateway that is available on the NI website.
(3,058 Views)
A colleague of mine has some good suggestions on this matter on the following thread:
http://forums.ni.com/t5/LabVIEW/Scilab-Script-in-Labview/td-p/748167
Please let us know if this helps.
Daniel G.
http://www.ni.com/support
Daniel G.
Semiconductor & Wireless
(3,014 Views)
