09-26-2005 07:23 AM
09-27-2005
06:37 PM
- last edited on
09-10-2026
02:48 PM
by
Content Cleaner
Hey Lost And Found,
There is actually a great example on using .dsl files with DataSocket. You can append "file:" to the beginning of the path of your .dsl file, and wire it directly into the "connection in" pin of the DS Read. Check out the example here: http://digital.ni.com/public.nsf/websearch/FCC19AF27EFED9A5862569A500709C58?OpenDocument . I think that it will provide everything you need and if not, just ask.
Hope this helps!
Megan B.
09-28-2005 09:44 AM
