Showing results forĀ
Search instead forĀ
Did you mean:Ā
Using the for loop iteration number as variable outside loop
I've very little experience with labview, and trying to design a program which generate a signal inside a for loop and each iteration the frequency of the signal is increased, basically I need to be able to use the for loop iteration number (i.e whether it's iteration 1, 2, 3 etc.) to multiply with a step size to add to the initial start frequency. I've tried shift registers etc. but can't seem to get it too work, any help would be greatly appreciated.
Message 1 of 20
(5,935 Views)
Do you see the little "index" terminal, blue square with "i" inside it on the lower left?  This is the For loop index, starts at 0 and increments by 1 for every loop.  Just wire it ...  This generates an array of even numbers, 0 .. 18.
Message 2 of 20
(5,923 Views)
I think that code (or very similar) is already placed in at least a dozen of posts, so only a screenshot:
Norbert
Norbert
Expert: Geometry
Message 3 of 20
(5,911 Views)
Consider the Ramp Pattern function to create an array of frequencies that you need and just write the array into a for loop.
Message 4 of 20
(5,901 Views)
Thanks for both replies, Norbert your solution was perfect, I had the logic located outside the loop and was getting different kinds of errors etc. but it's working perfect now thanks again.
Message 5 of 20
(5,893 Views)
There is also the simple Ramp Pattern VI that you could use to generate your points of interest.
Message 6 of 20
(5,890 Views)
I'll have a look at this and try implement it, thanks
Message 7 of 20
(5,882 Views)
One final question, I've searched the forums but can't seem to find an answer for a for loop, for testing I'm viewing the generated signal on an oscilliscope, but the loops execute far too quicky to see it, is there any way to hold a loop for a desired amount of time before beginning the next iteration. I've found lots of solutions for while loops.
Message 8 of 20
(5,877 Views)
Put a wait function inside of the For Loop.
Message 9 of 20
(5,868 Views)
Why would the solution for a for loop be any different than a while loop?
Message 10 of 20
(5,851 Views)
