Using two Dataq at once
Hello, Im trying to use Two different DI-2108 Dataq instruments at once. One to record the Voltages and the other to record the Currents. However, When I try to run it the system seems to get confused and only records data from one of the DI-2108 instruments. And when I check the Windaq dashboard it says that only one of the Instruments is active. I can get it to record the data for only one device at a time. Any suggestions one what I can do? here are some images of two different methods I have tried
(2,054 Views)
You will get more help if you attach the actual code instead of a picture of your monitor.
Former Certified LabVIEW Developer (CLD)
Currently using LabVIEW 2022
(2,024 Views)
Here is one of my attempts. The majority of the code is the same. The only thing changed was the in the images i provided
(2,017 Views)
