Windows 10 and Antimalware Service Executable
I've been seeing high CPU and Memory use from the Microsoft Antimalware Service Executable when I open a LabVIEW project or VI.
I have noticed this on several different Windows 10 development PCs.
Lately the problem seems to be worse, often causing the VI in question (and the entire PC) to run very poorly until the antivirus is done.  Then the CPU drops to normal and everything works the way it should.
Just curious if anyone else has seen this issue or similar with Windows 10 and if they have found any successful fixes or work arounds other than just waiting.
Patrick Allen: FunctionalityUnlimited.ca
Message 1 of 1
(1,628 Views)
