VI Logger: no data in task, but tests are ok
I have created a task in VI Logger to track voltage.  Inside of the 'Edit Task' menu, every thing runs as expected.  When I select 'Run Task' the real time chart appears, but no data is captured.  The real time chart runs, but no data is plotted and "(No Data)" is printed beside the channel in the legend.
The single channel in the channel menu is selected 'Log Enabled', I've also selected 'Begin logging when acquisition starts'.
Thank you for your help.
(2,488 Views)
Hi John,
How many samples are you trying to acquire, and at what rate?  Also, do you have any time conditions set?  It is possible that the task is taking a long time to acquire all the samples, or it is waiting for a certain time/day to start.
If that is not the case, what version of VI Logger are you running?
Justin M
(2,475 Views)
