VI Opens when Project is Opened
Has anyone seen this issue?  One file of many keeps opening automatically when I open the project.  Can't find any reason why this VI is opening.  Always the same VI and happens every time.
Thanks!
Matt
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
(4,635 Views)
Accepted by mfitzsimons
Look at the properties for that VI.
Look in the WINDOW APPEARANCE category.
Does it have SHOW FRONT PANEL WHEN LOADED checked?
Steve Bird
Culverson.com
LinkedIn
(4,624 Views)
Can't find anything checked or different from other VIs.  It is part of a class.  Thinking about deleting the class from the project and readding back into the project to see if it goes away.  Even checked the .LVPROG file to see if there was something in there causing the VI to open.  Nothing.
Thanks!
Matthew Fitzsimons
(4,598 Views)
My bad!  Source control prevented the save and you did provide the corrrect answer.  Thanks!
Matt
Matthew Fitzsimons
(4,595 Views)
I'm seeing the exact same behavior, only...."Show front panel when loaded" is checked AND grayed out. Ideas for how to uncheck this disabled box?
(3,314 Views)
Fixed it by dropping this in my VI, running once, and removing:
Still no idea how it got in this state though...!
(3,299 Views)
Under the "Category: Window Appearance" make sure to take a picture of your "Customize: Window Appearance" settings.
The "Default" option seems to have the "Show front panel when loaded" option unchecked. Click the "Default" option.  Then apply your necessary settings from the picture you took before.
(1,081 Views)
