VI Server in the real time target and Vi client under the local computer
   In my project i want to make a data communication between a vi server which is runnig in the real time target and a vi client runs under the local computer (My Computer target).
My problem is when i Click the property terminal of the property node function (located on the Functions>>All Functions>>
Application Control palette) , i don't find the front panel open option from the shortcut menu.
Thanks.
(2,875 Views)
The Front Panel options are methods.  Try dropping an Invoke Node down instead of a Property Node.
(2,762 Views)
