VI Snippet bug
I was trying to use the new LabVIEW 2009 VI snippet tool and got one semi serious problem, and one serious bug.
I tried to get this snippet right.
First problem was that the VI must be save before 'Snipping'.
Second is taht when I tried to capture the event frame I got a series of dialog stating that I sould report it to NI tech personel.
Third is that  the whole VI was captured.
In the attachment (temp.zip) is the XControl that created this (LabVIEW 2009), I have reproduced this even after a LV restart.
I only tried to capture the event structure inside the facade VI.
Ton
PS I am serious not just to diss the snippet tool
Message Edited by TonP on 08-05-2009 01:35 PM
Message Edited by TonP on 08-05-2009 01:38 PM
My LabVIEW Ideas
(4,756 Views)
Accepted by TCPlomp
Hello Ton,
thank you so much for your post. I created a new XControl and was able to reproduce it. It looks like it has something to do with the events that are used in the events structure (like direction change). I will file this problem.
Martijn S
Applications Engineer
NI Netherlands
(4,663 Views)
This was reported to R&D (CAR # 182002) for further investigation.
Roy
(4,623 Views)
Hi Roy,
one more problem with snippet creation...
See attached vi and according snippet.png. In the snippet the content of a [array of] cluster constant is invisible - which is rather annoying when that is just the main part of an example...
Message Edited by GerdW on 09-12-2009 05:49 PM
(4,496 Views)
Hello GerdW,
the cluster is coming visible again when placing the cluster back into the block diagram. I noticed a Corrective Action Request which explains the same problem; it looks like the elements within the cluster are shifted. This CAR (# 184059) is already under investigation.
Thank you so much for bringing this problem up,
Martijn S
NI Netherlands
(4,454 Views)
