VI crashes labVIEW on opening
I was able to open the file I uploaded in LabVIEW 10.0f2. Which version of LabVIEW 10 do you have?
Message 11 of 37
(2,317 Views)
By the way, you may want to review the Knowledge Base article on the Producer-Consumer architecture, which is what you seem to be trying to use.
Message 12 of 37
(2,315 Views)
Could one of your subVI's being causing the crash?
I was able to open the VI just fine in 10.0f2, but I had to tell it to ignore the half dozen or so missing subVI's.
Message 13 of 37
(2,309 Views)
I'm running labVIEW 10.0 Development system.
I just get a white faded out window with a prompt to close labview when I try to open the vi...
Message 14 of 37
(2,308 Views)
Would it help to upload the vi's that i call from the top-level vi?
Message 15 of 37
(2,301 Views)
If that's what's really causing the crash, then yes, it would help.
You may also wish to update your LabVIEW, since there has been a patch released for LabVIEW 10.
Message 16 of 37
(2,299 Views)
Ok thanks, I'm downloading the patch now as we speak, will upload the sub vi's i'm using...
Message 17 of 37
(2,293 Views)
Sub vi's called from top-level vi attached below.
I'd be grateful if you could have a look when you've time.
Message 18 of 37
(2,292 Views)
No problems opening all the VIs in 10.0f2.
Message 19 of 37
(2,288 Views)
Same here.  I also went back to the originally posted VI, and had no problems opening that either in 10.0f2.
Message 20 of 37
(2,284 Views)
