VI crashes labVIEW on opening
Ok well once the patch has finished downloading, i'll try again. I really could do without having to start again...
Message 21 of 37
(1,616 Views)
It's still crashing... i'm obviously doing something wrong if yer getting it to open at yer end.. I have several versions of the same sub-vi's saved in different locations, maybe this is causing the problem..?
Message 22 of 37
(1,608 Views)
It crashes my 10.0 on win XP.
The crash occurs immediately after ignoring the missing sub-vis
It also crashes if I attempt to open a reference to it.
MC
Message 23 of 37
(1,604 Views)
Smercurio_fc and Ravens Fan,
I just managed to open the vi there and all the sub vi's (and backed them upSmiley Happy). I wish to thank ye again especially Smercurio. Ye have saved me so much time.
If there's a contribution to this forum or anything like that I'd happily partake with some of my hard earned cash.
Thanks lads (or ladies..)
Message 24 of 37
(1,592 Views)
click on the + Kudos button...
And select his post as Accepted Solution.
I have to check if I have the latest patch for LabVIEW 2010..
Message 25 of 37
(1,586 Views)
So it sounds like the latest patch has fixed the problem.  That's good.
I searched the NI.com knowledge base and came across a couple things that may explain your crash.
LabVIEW 2010 f2 Patch Details
I think your problem is probably related to CAR #243106 which was explained further in this KB article.
Broken Wires or Terminals with Insert into Array Primitive Crashes LabVIEW 2010
Your VI did have some scraps of code including an insert into array function with no wire going into it, thus a broken wire coming out of it.
Message 26 of 37
(1,580 Views)
I have 2010 with SP1 and i still get this crappy error when trying to open a front panel,
which surprisingly works well in 8.2.1
this is why i always hate to go to a newer version.
All you get is errors which are somehow unexplainable!!!!Smiley Mad
what resolution is there for me? reinstall? everything? recode everything?
this is all not acceptable!!!
Message 27 of 37
(1,557 Views)
can you post your code so that others may check to see if it causes a crash on their PC?
LabVIEW 2010 SP1 seems quite solid.
Message 28 of 37
(1,536 Views)
thats not possible because my project covers like 7000 vi`s...
i now found out that i get at least an error with LV8.5  telling me something about an "Insane Error..."
Message 29 of 37
(1,528 Views)
here the error:
I am pretty sure that this is the same error that crashes LabvIew 2010
Message 30 of 37
(1,525 Views)
