VI does not open anymore
I was able to open it in LV 2010.  However, the block diagram is password protected.  There also seems to be a decoration way off to the upper left of the front panel and a button way to the lower right.  Maybe one or both of these things are causing you problems when opening.  I tried to use the code capture tool to get a screenshot of the block diagram, but it ultimately led to a series of Not Enough Memory dialog boxes.
See the attached screenshot, and also how much actual front panel is seen and not seen on the navigation window.
If you know the password, it might be possible for one of us to try to resave it.
Message 11 of 26
(2,751 Views)
Yes please any way we can restore this file will be a GREAT HELP..
the password is "BlueSky_j196"
But I have only LabVIEW 2009 is there a way to save it in 2009 format ?
Message 12 of 26
(2,742 Views)
Also The last thing I did was change somethings to the Mixed signal graph on the GUI And I suspect that this casued some issues.
could you please delete this mixed signal graph and send the vi to me in 2009 format.
Message 13 of 26
(2,728 Views)
Accepted by vbs
Try this saved as LV 2009.
I brought in the far flung controls on the front panel, as well as tried to bring together the block diagram terminals and functions a bit tighter.  Sometimes way out of range entities can cause problems with the way LabVIEW saves files.
Where you have a lot of related controls or indicators, I would recommend doing a little bit of work consolidating them into clusters.
Message 14 of 26
(2,710 Views)
Outside of labview, windows makes shadow copies, I have used this to sabe a corrupted VI in the past, right click on the vi icon and select properties, go to previous versions tab (if you have this on your system) and select a version from a prior date when the vi did work.  As a habit you will find that ziping work each day can save you from this in the future.
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
Message 15 of 26
(2,692 Views)
VBS,
Be careful!
By accepting this code from Ravens Fan you are agreeing to be his servant for life concidering he may have saved your professional carreer! Smiley Tongue
No I'm kidding but decorating all of his posts with Kudos is in order.
Ben
PS Marking his post as a solution also will give him another point for this month.
Message 16 of 26
(2,687 Views)
Wow !! It is soooo goood to see this VI open again in my computer... THANKS Ravens Fan
Thanks everyone for contributing.. Kudos to Ravens Fan !!
Message 17 of 26
(2,670 Views)
You have, of course, now learned to use backups, right?
Message 18 of 26
(2,659 Views)
I don't seem to have this feature.. Is this somthing that needs to be enabled in the Windows. We used XP so maybe this feature is not there in XP.
Message 19 of 26
(2,643 Views)
Yes, We have active directory in the server and a source control system, Both had 2 months old copies.. But lesson learnt, Thanks to the forum without a heavy price 🙂
Message 20 of 26
(2,642 Views)
