VI executable (.exe) without running, running continuously, abort execution and pause button
Dear All,
I want to make build an application (.exe) from a VI and I don´t want the front panel to show the running, running continuously, abort execution and pause buttons (VI Toolbar Buttons). The purpose is to make a SCADA application without the risk of accidental STOP.
Maybe the question is too trivial but I am new to LabVIEW and I don´t find the way to do it (I unchecked the "Show Abort Button", from the VI properties menuo of the Build Specifications but nothing happens).
Thank you very much
Javier
(5,189 Views)
Just hide the entire toolbar.
(5,180 Views)
Accepted by Javio
Thank You very much.
The I found the way to do it in the help "Customize Window Appearance Dialog Box".
File->VI properties->Window Appearance->Customize.
Thanks again.
Javio
(5,161 Views)
