VI gets corrupted and will not operate when moved to another system
I have a test program that I am needing to run on more than 1 system.  When I try to move it from the computer I developed it on, to the test system computer I get corrupted VI errors.  The number of corruptions and the VIs that get damaged seem to be random.  This is also the case if I build an executable and move that to a different system.  Every time I try it I get different sub-VI errors.  Any suggestions would be helpful.
Message 1 of 12
(3,593 Views)
There's a difference between a corrupted VI, a VI with a broken arrow, and a VI that returns an error. Please explain with some details.
Message 2 of 12
(3,580 Views)
Please add me to the "I'm baffled list".
Ben
Message 3 of 12
(3,576 Views)
Its not a broken arrow, an error window pops up and gives an error message, I'll try to catch the message again, but I think it is error 23.  It also mentions lack of memory to open and data corruption.  These VI's work before I try to move them.
Message 4 of 12
(3,568 Views)
Did you merely copy the exe or did you create an installer that includes the run time engine and all hardware drivers?
Message 5 of 12
(3,564 Views)
Well, i'm not as baffled as I was previously but I'd still like to see that error message before I speculate.
Ben
Message 6 of 12
(3,563 Views)
There's a difference between a corrupted VI, a VI with a broken arrow,...
And a VI with a broken arrow isn't nearly as dangerous as Broken Arrow with a VI. Smiley Very Happy
But seriously, do you use Toolkits on the computer that works? Esp. Microsoft stuff?
Richard
Message 7 of 12
(3,560 Views)
THat is a great line Broken. Maybe its time for you to give yourself a signature?
Ben
Message 8 of 12
(3,555 Views)
This is the error, the only change is that it is not always the same VI that has the error loading.
Message 9 of 12
(3,528 Views)
Clarifications
1) You  have no problem with these VIs on the developmen machine? (T/F)
2) Every machine you try to move the VIs too show you this error? (T/F)
3) NO VIs including small quickies will move from your development machine and open on any other machine? (T/F)
4) VI developed on other machines (including small quickies) will open on your development machine without any error? (T/F)
Ben
Message 10 of 12
(3,518 Views)
