VI gets corrupted and will not operate when moved to another system
Clarifications
1) You  have no problem with these VIs on the developmen machine? (T/F)
2) Every machine you try to move the VIs too show you this error? (T/F)
3) NO VIs including small quickies will move from your development machine and open on any other machine? (T/F)
4) VI developed on other machines (including small quickies) will open on your development machine without any error? (T/F)
1) T, no problems running them on the computer they were built on
2) T, once a VI shows this, it does it anywhere it is put, I think it may be happening when it is copied to the media that is moving it
3)F, some VI's will move fine.  large small doesn't seem to matter.  But when moving more than 1 VI at least 1 has this issue
4) F, I ended up doing most of the development on the test machine because moving to or from the develop machine had issues.  If I made changes on one it would not load on the other.  Didn't matter where it started or ended.  I even tried using more than 1 USB drive to transfer the files and still have the issue.
Message 11 of 12
(389 Views)
The only suggestion i can offer is to scan that development machine for viruses.
Maybe others have ideas,
Ben
Message 12 of 12
(388 Views)
