VI has an error of type 6208
I am using LabVIEW 8.0.
I am trying to build an executable file from a VI that runs without problems. LabVIEW creates the executable file without errors but when i run the executable fileI receive an error that reads: "VI has an error of type 6208The full development version of LabVIEW is required to fix the errors
Any thoughts on what I can do to find out what is going on
Thanasis
(4,650 Views)
It sounds like you are missing some drivers or you have some dll dependancies that aren't being fulfilled. Try eliminating parts of your code and run the executable until it works then you have an idea where the problem is and we could try help you further!
(4,647 Views)
Seems like you are missing some drivers
(4,643 Views)
