power array
Hi
How to take power or root of each element of 1-D array?
Message 1 of 8
(6,098 Views)
Can you please provide more details about your 1-D array?
Regards
MY
Message 2 of 8
(6,093 Views)
a simple 1-d array what do u need more?
like
1
2
3
4
5
6
7
8
9
Message 3 of 8
(6,084 Views)
Hi Quaidian,
what  do you mean a Power or Root element?
Regards
MY
Message 4 of 8
(6,081 Views)
i mean to take cube of each element or take square root of each element
1        1         1
2        4         1.4
3        9         1.7
Message 5 of 8
(6,075 Views)
I have attached an example. May that can help you.
Regards
MY
Message 6 of 8
(6,067 Views)
Accepted by topic author quaidian
Have you tried to connect an array to the Square Root Function
Owning Palette: Numeric Functions
Computes the square root of the input value.If x is negative, the square root is NaN unless x is complex. If x is a matrix, this function takes the matrix square root of x. The connector pane displays the default data types for this polymorphic function. x can be a scalar number, array or cluster of numbers, array of clusters of numbers, and so on.
Remember always enable context help (Ctrl+h), and do not be afraid to dive into the detailed help option
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 7 of 8
(6,063 Views)
ok i had negative numbers in the array
Message 8 of 8
(6,060 Views)
