VI in SubPanel does not get Pane Size event on window resize
I'm having an issue similar to the one posted here:
https://forums.ni.com/t5/LabVIEW/Resize-VI-in-Subpanel-when-main-VI-is-resized/td-p/1978763
which had a recommended solution to use the Pane Size event instead of the Panel Resize event as found here:
https://lavag.org/topic/16483-subpanel-resize-event/
In the attached demonstration files, the VI in the SubPanel does generate both the Panel Resize and Pane Size events when operated in stand-alone, windowed mode. However, it does not fire either event when loaded into the SubPanel control in the window with the splitter bars.
Am I missing something?
_______________________________________________________________
"Computers are useless. They can only give you answers." - Pablo Picasso
(2,648 Views)
Accepted by rwunderl
You are not running the VI that you insert into the subpanel. Since its not running, of course it can't receive events - it can't do anything!
(2,614 Views)
Clearly, my example was a bit too simple. Hahaha!
Thank you. It works as expected now.
(2,609 Views)
