VI in SubPanel does not get Pane Size event on window resize
I'm having an issue similar to the one posted here:
https://forums.ni.com/t5/LabVIEW/Resize-VI-in-Subpanel-when-main-VI-is-resized/td-p/1978763
which had a recommended solution to use the Pane Size event instead of the Panel Resize event as found here:
https://lavag.org/topic/16483-subpanel-resize-event/
In the attached demonstration files, the VI in the SubPanel does generate both the Panel Resize and Pane Size events when operated in stand-alone, windowed mode. However, it does not fire either event when loaded into the SubPanel control in the window with the splitter bars.
Am I missing something?
_______________________________________________________________
"Computers are useless. They can only give you answers." - Pablo Picasso
(2,651 Views)
Accepted by topic author rwunderl
You are not running the VI that you insert into the subpanel. Since its not running, of course it can't receive events - it can't do anything!
(2,617 Views)
Clearly, my example was a bit too simple. Hahaha!
Thank you. It works as expected now.
(2,612 Views)
