VI linking
I'm not sure what your level is, or what the problem is, so I'll begin at
the basics.
To pass values (of any type) to another VI, you have to connect the
indicators to the connector pane. Right click the vi icon in the top right,
and select Show Connector. You should always select the 4X4X4 connector
pane, with the Patterns option (again, right click the icon). In 8.5 this is
the default (I think since 8.0, but I'm not sure). Then, click any of the
little squares in the connector pane (the icon, but now it shows the grid),
and then one of the indicators on the front panel. Now, the VI has an
output. You can do the same with the second VI, only now select a control.
This becomes a new input of the VI. In a main VI, you can now connect the
two, if the two data types are the same.
One problem with your senario is that the user selects settings in a
control. To be able to pass the control values to another VI, you'll have to
create an indicator of each control you want to pass. Then connect the new
indicators to the connector pane, and you can pass the control values to the
next VI.
Another problem is that you might have several (related) values. You can
bundle them in a bundle or cluster, to save connectors. You'll find that it
pays off to make a strickt type def of those clusters, so you can change
them all at once.
Hope it help, just let us know where it goes wrong.
Wiebe.
Message 11 of 16
(1,632 Views)
Hey!!
I'm using LV8.2 .cant open what you have made.Help?!?
tnx
Message 12 of 16
(1,622 Views)
Here y'are.  Don't forget to answer the questions folks have asked; we can't help very well if we don't know what you've tried and the specific issues you're having.
Jim
Jim
Message 13 of 16
(1,616 Views)
Thanks guys !
I did tried the subVi part .But i guess the global variable came out to be a better choice.
DeWalker
Message 14 of 16
(1,571 Views)
***Did try****Smiley Indifferent
Message 15 of 16
(1,570 Views)
Eventually, this will bite you...
Never use globals, if you can avoid it. They always can be avoided, so never
use them... But suit yourself.
Wiebe.
Message 16 of 16
(1,561 Views)
